code premix
Old   October 19, 2004, 09:07
Default code premix
A. Belcadi
I found a problem in the use of Premix code. This code gives me good results for a stoichiometry mixture (rich=1.0). forlean and rich mixtures, this code does not finish calculation correctly. My question is as follows: which are the parameters in which I will play to solve this problem?
Old   October 22, 2004, 09:09
Default Re: code premix
T
I think probably the answers lies in the initial condition so lets say if you have converged solution at some quivalence ratio then you can take this converged solution as the intial condition and procedd to the rich case with slight increment of equivalnce ratio. I hope you understand evrything T
Thread Tools
Trackbacks are On
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Debugging Unsteady 2-D Panel Method Code: Wake Modeling RajeshAero Main CFD Forum 5 November 10, 2011 06:48
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
