-   -   Triangular mesh - fully developed flow between parallel plate (http://www.cfd-online.com/Forums/main/82419-triangular-mesh-fully-developed-flow-between-parallel-plate.html)
Amir_Ghasemi November 25, 2010 13:54
Dear Friends,
I want to simulate a fully developed flow between infinite parallel plate (2-D), with prescribed pressure for inlet and outlet. When I use rectangular (structured) mesh, the results are consistent with analytical solution:
u = h ^ 2 (2 * mio) * ( Delta P / L) * ((y/h) ^ 2 - (y/a) )
but when I use 3-node triangular mesh (with any form I tested) the resulted velocity profile are not correct; lower velocity is obtained for a prescribed pressure gradient.
I tried finer triangular mesh, but no better results achieved.
I Use ADINA-8.5 Software which is finite element based.
Any suggestion and guidance is really appreciated.:)
otd November 25, 2010 19:44
Should (y/a) in your formula be (y/a)^2 ?
Amir_Ghasemi November 26, 2010 13:18
Thanks for your reply, it should be y/h, but this is not a mistake, there is a fundamental error in using triangular mesh, but I don't know what is that?
Amir_Ghasemi November 28, 2010 05:52
Solved
I changed the upwind type from Finite Element to Finite Volume in ADINA and know the results are correct:).
It can be found here in ADINA:
Control -> Miscellaneous option -> Default upwinding type > Finite Element:)
