Regrd to CFX-View
I use some example provided by the BOOK(example) to test CFX-View. The whole process described below: 1. I copy the m01.dmp to c:\ 2. run CFX-view 3. I get the MAIN-MENU-canvas window.
But There is nothing there. I don't know what is the problem. Thank you for answer in advance. |
Re: Regrd to CFX-View
you have a blank screen because you need to select 1)what plane you want to study e.g. x plane at x = 0.5m or so.
2) you need to go into the vectors or contours part and click plot after selecting what variable you want to study. If you want to see your geometry you go into the Mesh tab and select full model outline or plane outling and click plot. Have a play around in there and see what you come up with Good Luck! Regards Simon Assender |
