Boundary conditions in the proyection method
Old   November 1, 2004, 03:55
Default Boundary conditions in the proyection method
Oscar Salazar
Hi
Is it possible to apply the projection method in a system with combination of Neuman and Dirichlet boundary conditions for the velocity? sample: flow inside a pipe
Boundary conditions (cylindrical 2D Navier-Stokes):
inflow (z=0): Uz(0,r) = 3 , Ur(0,r) = 0
outflow (z=L): dUz/dz = 0 , Ur(0,r) = 0
center (r=0): dUz/dr = 0 , Ur(z,0) = 0
wall (r=R): Uz(z,R) = 0 , Ur (z,R) = 0
thanks
Old   November 1, 2004, 05:03
Default Re: Boundary conditions in the proyection method
Junseok Kim
I think you can still use the projection method, by the way, you may want to change inflow (z=0): Uz(0,r) = 3 as someting like
Uz(0,r) = 3(R-r)(R+r)/R^2
Old   November 4, 2004, 01:25
J.Deng
I'm trying program codes for projection method on staggerd grid. When simulate a problem like 'lid-driven cavity flow', the boudary conditions are easy to set, but when a outflow is included, the boudary condition is hard to impose. Most references I have found are concerned about the Dirichlet bondary conditions, who can provide me some more detailed papers on the boudary conditions for projection method? Thanks!
Old   November 4, 2004, 05:23
Halim Choi
Your outflow condition is not right. If you use the velocity boundary condition at the exit (that means you do not use the pressure boundary condition at the exit), the mass conservation must be satisfied at the outlet. Try following way.
(1) First impose at z=L, dUz/dz=0, dUr/dz=0 such that;
Do J=2,JMAX-1
Uz(IMAX,J)=Uz(IMAX-1,J)
Ur(IMAX,J)=Ur(IMAX-1,J)
end do
(2) Calculate mass flow rate at inlet
Flowin=0.
Do J=2,JMAX-1
Flowin=Flowin+density(1,J)*r(J)*delta_r(J)*Uz(1,J)
end do
where delta_r is the size of each control volume in r_direction.
(3) Calculate mass flow rate at exit
Flowout=0.
Do J=2,JMAX-1
Flowout=Flowout+density(1,J)*r(J)*delta_r(J)*Uz(IM AX,J)
end do
(4) Calculate Factor=Flowin/Flowout
(5) Imposed the velocity at exit such that
Do J=2,JMAX-1
Uz(IMAX,J)=Factor*Uz(IMAX,J)
end do
Above method is what SIMPLE people are usually doing.
I hope this helps.
Halim Choi
Old   November 5, 2004, 10:28
Oscar Link
HI! look at the papers by Philip Gresho & Co.:
(1984) Int. J. Num. Meth. in Fluids, Vol4, 557-598 (1987) Int. J. Num. Meth. in Fluids, Vol7, 1111-1145 (1990) Int. J. Num. Meth. in Fluids, Vol11, 587-620
I found there a lot of usefull tips, but the articles were too much theoretical oriented for me. Anyway, I think that it is a good start!
Greetings,
Oscar.
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Boundary Element Method = Boundary integral method? aiqch Main CFD Forum 0 April 3, 2010 16:29
Open Channel Boundary Conditions via journal Matteo FLUENT 0 January 21, 2008 12:05
compressible boundary conditions vivian Main CFD Forum 8 April 24, 2006 06:23
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
