How to refine O-grid hexa mesh?
Old   October 30, 2004, 02:56
Default How to refine O-grid hexa mesh?
Pete
I'm doing some mesh dependency test for my elbow diffuser. I used the hexa mesh with O topology. Just wonder if anyone has experience in refining this type of mesh effectively?
I tried to double the grid point on all grid lines but the number of elements increases tremendously. Any idea how to arrange it in such a way that the asymtotic solution can be observed/estimated properly and yet the number of nodes is not increased tremendously?
Thanks for your advice.
Cheers, Pete
Old   October 30, 2004, 03:04
Default Re: How to refine O-grid hexa mesh?
Pete
Oppss.... Sorry.. I forget to say that I'm using the SSG Reynold Stress & SST turbulence model right now. Should I consider my Y+ value while refining the mesh in this case? Any comment is very welcomed.
Old   November 15, 2004, 07:40
Anshul Gupta
Why did you increase the nodes on all the grid lines? You should increase the nodes only those grid lines which are going out of the walls and even there it should have concentration towards the wall with non-uniform spacing..
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[ICEM] Hexa Mesh Smoothing Jules ANSYS Meshing & Geometry 6 December 4, 2010 19:00
icem hexa mesh parts pb jaber FLUENT 0 June 12, 2009 19:06
