Boundary Layer - dimensionless wall distance y+ |
October 31, 2011, 15:21 |
Martin R.
Rep Power: 14 |
Hello everyone,
first of all, if that is the wrong forum for my question, i kindly ask the admins to correct that, because i was not sure where to post it. I am currently trying to generate a boundary layer mesh for a laminar flow (Re<10000) over a 2D airfoil. The question is now, how "high" should the first row of boundary layer cells be in this laminar flow? or ? Kind regards, Martin Rei |
November 2, 2011, 01:10 |
Sonil Singh
Rep Power: 14 |
Martin
Choice of what value of y+ to take depends on how accurately are you trying to capture the flow in laminar sub-layer in a turbulent flow problem. If you make a mesh with y+ 30 then you will have to perform your simulation using a turbulence modelling with wall scales (this will approximated the effects of laminar sub layer and buffer zone numerically) fora turbulent flow. y+=1 or less must be used if you have enough computing power and you need not use wall scale in this case. In your case of a low reynolds number flow these things may not matter... Still i would suggest mesh as fine as possible, as a high resolution mesh is always preferable if we have enough computing resource. |
November 2, 2011, 04:08 |
Martin R.
Rep Power: 14 |
November 2, 2011, 05:57 |
Sonil Singh
Rep Power: 14 |
See it all boils down to resolving your boundary layer...
I would suggest you to calculate B.L. thickness with respect to chord using formula for calculating B.L. thickness for laminar flow over flat plate and try to have minimum of 20 layers inside that length... and keep the growth ratio of the grid inside 1.15 in the B.L. |
November 3, 2011, 01:14 |
#5 | ||
ps. If you refine mesh sufficienntly high, then you may reach the DNS with laminar flow solver !!!! |
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 20:05 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 08:47 |
