How to digitised a curve
Old   October 25, 2004, 11:31
Default How to digitised a curve
Anne
I found very useful experimental curve in literature, and I want to digitize it and feed into my CFD code. Does anybody know how to do it? Please give me some info and hint on it1
Thanks ahead!
Old   October 25, 2004, 12:04
Default Re: How to digitised a curve
Tom
Try to read some (x,y) coordinates manually from the curve. Once you have the coordinates, fit an orthogonal polynomial (i.e. discrete fourier, Chebyshev (rescaled to [-1,1], or other polynomial) using a collocation (gridpoint) or spectral coefficient approach. This is low tech, but may be your most efficient method.
Old   October 25, 2004, 13:32
Anne
thanks, Tom.
Can you give me more detail on it. I mean the tools, such as what software (matlab, tecplot, origin) is best to fit the selected data. And what is the collocation (gridpoint) or spectral coefficient approach.
Thanks a lot for your reply1
Old   October 25, 2004, 15:55
Jonas Larsson
I always use the Engague Digitizer - a free tool which allows you to digitize a scanned plot. You can download it from here:
http://digitizer.sourceforge.net/
It works really well and has lost of nice features.
Old   October 25, 2004, 17:11
Anne
thanks a lot, Jonas, that's really helpful.
Old   October 26, 2004, 13:10
Amadou Sowe
I use the same one too.
Old   October 27, 2004, 07:59
Anne
Hi, dear all,
After digitizing the curve, a set of data is obtained. If I want to fit them, such as lnear fit, polynomial fit, even a distribution function, what software do you recommend? I used Origin before, and the fitting function is too simple. Can you give me any suggestion?
Thanks !
Old   October 27, 2004, 08:11
Jörn Beilke
The best I have used is Xact (www.scilab.de) but it is not really cheap.
Old   October 27, 2004, 10:49
anindya
Origin Lab is very Good. There are lots of Curve fitting options from simple to complex. You have to experiment which curve fits best. Dont just try the default linear ones. Try the non-linear ones and there are hundred and hundreds of options there. Also you can use TableCurve 2D.
Old   October 27, 2004, 12:06
Amadou Sowe
Matlab is my tool of choice.
Old   October 27, 2004, 17:32
  #11
Anne
Then, could you please tell me more on how to do it. I only know the polyfit function for polynomial fit. Is there any other functions, in which toolbox? Is it flexible to use?
Thanks again!
Old   October 28, 2004, 09:31
  #12
Amadou Sowe
This is difficult for me to answer, because it is problem dependent. If it is 2-D data I will first us the plot function to see what it looks like. After this step I will decide whether I need a hyperbolic, exponential, polynomial, or some other fit.
Matlab has a section on regression and curve fitting in addition to their curve fitting, statistic, and optimization tool boxes that are very helpful for curve fitting tasks. Good luck.
Old   November 18, 2004, 17:40
  #13
Mani
I like PlotDigitizer better than Engauge, but either program will work. PlotDigitizer is a Java program and works on various platforms.
http://plotdigitizer.sourceforge.net/
Nonlinear curve fitting is very powerful, as you can fit your data to any function that you specify (with a number of free coefficients). I like using xmgrace for this purpose. Like most other good programs, it's open source.
http://plasma-gate.weizmann.ac.il/Grace/
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
[ICEM] Smoothing a curve lost.identity ANSYS Meshing & Geometry 6 July 13, 2009 05:23
How to maintain spacing along a new curve? KB Main CFD Forum 2 June 5, 2007 16:45
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
