Some questions about incompressible flow,thx!
Hi guys,
i got some words on a book, but i cannot understood them very well, it said "In the low speed fluid and gas,they are treated as imcompressible flow.There was no change in the density,so there is no relationship between momentum equations and mass conservation equations". Well ,my question is ,why? THX! |
WHY? |
With density constant, momentum and conservation depend only on velocities and pressure. In 3-d flow, that's (for example) u, v, w, and p. With 3 momentum eqs. and continuity, that's 4 equations and 4 unknowns. They can (and are) solved without reference to Temperature, internal energy, etc.
Knowing u, v, w, p, etc, the energy equation is one equation in one unknown (temperature, internal energy, enthalpy, etc depending on the form you select for the equation). It might be better to say "the momentum equations are independent of the temperature" but temperature depends on the momentum and pressure. Some other folks might say the coupling between momentum-continuity and energy is one-way only. That thing about 'no relationship' is sort of confusing. Hope this helps, OTD |
Let non-dimensional pressure be: where is the constant background pressure, is the reference density and is the reference velocity. then the energy equation in non-dimensional form can be written as Here is the reference Mach number. If tends to zero then the energy equation coincides with continuity equation div(u)=0! Thus energy equation in itself "disappears" for incompressible flows (M->0)!;) Therefore "momentum equations & mass conservation equations are no relationship with energy equations" Details see for example in Wesseling's papers 1. van der Heul DR, Vuik C, Wesseling P. A conservative pressure correction method for compressible flow at all speeds.// Int. J. Numer. Meth. Fluids, 2002, v. 40, pp. 521-529. 2. I. Wenneker, A. Segal and P. Wesseling. A Mach-uniform unstructured grid method. // Int. J. Numer. Meth. Fluids, 2002, v. 40, pp. 1209-1235. |
thanks for your reply, i got the quetion`s answer, your answer is very clear.
