-   -   fluid mechanics HELP!! (http://www.cfd-online.com/Forums/main/83923-fluid-mechanics-help.html)
Adren022 January 15, 2011 05:42
I have not been able to find any software thats helping me in simulating or Obtaining results for pressure drop through a nozzle of decreasing diameter.
having tried the fluid option in ansys v10 dinn't understand how to use it,i have not undergone any training for the other software available for fluid simulations
is there a software that will help,ANSYS 12 and 13 are too costly to buy.
i don't know how to use star CD or open foam,for a noob which would be the best software to use for the above application i have mentioned.
i have to prove that my theoretical results are right with the help of a simulation
thank you :)
RossFS January 18, 2011 08:06
Surely there are experimental results in tables or charts which would save you the effort of trying to simulate the flow. Find a decent text book.
Adren022 January 18, 2011 11:33
i was hoping i could simulate it...But as you say i will look at other alternatives
do you have any suggestions of text books i could use ?
i use a book authored by DR.R.K.Bansal he is a local author,its a well written book but contains only basics
RossFS January 18, 2011 17:01
Having recently only started to conduct CFD simulations myself in ANSYS, I'd say that a little knowledge in this area is very dangerous as with out some good knowledge about the numerical methods used by the software and knowledge about the correct fluid settings to put in, you can very easily generate garbage for output but you are unlikely to know this.
CFD simulations themselves have to be validated with experimental results generally (just read up on the amount of calibration work the F1 guys do with their wind tunnels and CFD software), so I'd lean towards the experimental data.
search via: http://books.google.com/
you are likely to get a graph up of what you want exactly without having to head for a library.
DoHander January 18, 2011 21:56
Check this book:
http://www.amazon.com/Computational-.../dp/0070016852
especially chapter 7.
If you need help implementing the algorithm send me a message and we'll see how if I can help you.
Do
Adren022 January 19, 2011 01:11
Originally Posted by DoHander (Post 291060)
Check this book:
Do
thank you :) ...i will see if its available in my country or order it through flipkart
the above posts make more sense..i have zero knowledge in this field and don't really know which software to use,also we were taught only ANSYS 10 so i have no idea about the newer versions
are there any software that you'd recommend for noobs in this field ?
Adren022 January 19, 2011 01:13
Does simulation have to take place only using CFD techniques ?
can't i just use the fluid option in ANSYS 10 and get results for this ?
