[Sponsors] | |||||
Rep Power: 4 ![]() |
I am solving turbulence flow in centrifugal pump.I found "attached flow" in book Johann Friedrich Gülich "Centrifugal Pumps" but there is not explanation of it. Could you help me? Thanks in advance |
blaze
Rep Power: 6 ![]() |
Attached flow is the flow which has not separated from the body. For example in an airfoil, at low angles of attack the flow is attached ie the streamlines are such that they "stick" to the body.
But as you increase the AoA, the flow tends to "separate" as the fluid does not have enough momentum to stick to the surface. This is the general definition. I do not have the book hence cant be specific. |
You are right.Now that book has become more clear for me
![]() Thanks for replay. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
| Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
| The Definition of the Flow Angle | yangdick001 | NUMECA | 3 | February 23, 2011 20:58 |
| OpenFOAM14 for Mac OSX Darwin 104 | gschaider | OpenFOAM Installation | 118 | July 20, 2008 05:19 |
| Convergence Definition of Segregated Solver | Amir | FLUENT | 0 | April 18, 2006 06:21 |
