Cavitation model in compressible flows.
Like Tree1Likes
  • 1 Post By jinwon park
Old   March 19, 2008, 15:20
Default Cavitation model in compressible flows.
jinwon park
I am solving two-fluid flows which consist of gas and water. When I analyzed these, I had to put a cavitation model which detects the occurence of cavitation. For example, water is cavitationed if the pressure is lower than a vapor pressure. It is usually 0.05Bar. To include this model, I put p=MAX(p_EOS, p_vapor) in the code. It implies that the pressure in water is determined by a higher pressure between the calculated one and the vapor one. In doing so, I have sufferred from some numerical errors which provide incorrect waves. My question on that subject is that how we determine the speed of sound inside the cavitated region. Can anyone advice me to physically include the cavitation model in water field computings?
fedefrance likes this.
Old   May 11, 2015, 07:24
federico
fedefrance is on a distinguished road
I have the same problem, did you find a solution?
fedefrance is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
SIMPLE pressure correction in compressible flows Maarten de Jong Main CFD Forum 7 April 30, 2012 02:23
Realizable k-epsilon model for cavity flows vasuaero1988 FLUENT 1 September 27, 2010 03:06
about the mixture model and cavitation model lius FLUENT 2 January 11, 2006 04:55
Using non-premixed model on compressible flow Libing FLUENT 0 November 10, 2005 18:39
