-   -   ABAQUS vs ANSYS @ heat transfer analysis (http://www.cfd-online.com/Forums/main/8428-abaqus-vs-ansys-heat-transfer-analysis.html)
F Xu December 8, 2004 19:49
I am now wondering which one to use.
My problem is conductive heat transfer in biological materials considering the thermomechanical interactions. I have installed ABAQUS, but after use, I find its precessing is not very good and I am told that ANSYS is better. Can anybody have experience give me some advice?
Thank you
Feng
Joe Brian December 9, 2004 00:54
Re: ABAQUS vs ANSYS @ heat transfer analysis
Check the survey result..
http://www.polymerfem.com/modules.ph...sults&pollID=5
Then you can get some idea for the preprocessor
-Joe
F,.K. December 9, 2004 04:38
I would recommend the following:
Pre/Postprocessing : PATRAN Solver: ABAQUS
Advantage: excellent Preproccesor for meshing and Geometrie Cleanup (much more easy to handle than Ansys) and the leading nonlinear FEM solver which is absolut reliable
hope this helps
carlos December 9, 2004 05:54
I have some experience with ansys in heat transfer/structural mechanics problems. It is reliable and once you get used, its pre-processor is powerful (however if your problem is the mesh, try an independent mesher, eg patran, hypermesh, etc). You can do semi-coupled analyses between heat transfer/structural models.
RUPESH S SHELKE December 23, 2004 05:55
SHASHIDHARA .T January 13, 2005 06:47
Hello sir i am in problem in solving 9 layers thermomechanical stress problem subjected to temperature variation of +100 to -180
