boundary conditions
Old   January 26, 2011, 01:54
Default boundary conditions
abdul moqeet hai
abdul moqeet is on a distinguished road
Dear All,
i am new to cfd. in my MSc project i have to use cfd as a tool. air is to be simulated in a rectangular pipe, suction of air is taking place at outlet or exit. only the air velocity is known in the pipe. tell me about the boundary conditions which i should use for this suction at outlet case????? thanks in advance
Abdul
abdul moqeet is offline   Reply With Quote
Old   January 28, 2011, 20:11
RossFS is on a distinguished road
Just set the exit pressure and maybe a mass flow rate?
The specific name of the boundary condition would depend on the software you are using(?)
RossFS is offline   Reply With Quote
Old   January 29, 2011, 06:48
Default hi
abdul moqeet hai
dear,
i'm using fluent 6.3.26. currently i'm using velocity inlet boundary condition, so in result the standard deviation of velocity at the inlet face is minimum and std dev of velocity at the outlet is maximum. but it will not be true in orignal case as suction is at outlet so std deviation of velocity at oulet face should be minimum...
please guide
i look forward for your response
Old   January 30, 2011, 02:31
I'd say that the tighter boundary conditions would need to be set at the suction end.
The best way to work out what settings you should use at either end is to check out the user guide for Fluent (user_guide.pdf I think) in the Fluent installation directory. The guide is >= 1000 pages in length and appeared to be well written in the bit I looked at. This document will give you detailed descriptions of the boundary conditions that you can set in Fluent and the conditions that they are suited to modelling.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
