May 13, 1999, 01:39 |
CFD Code
Sir,
We are looking for a commercially available CFD code, which should capable of performing follwing things. 1. It should compute, subsonic, transonic and supersoinc flows and it should capable of capture shocks sharply. ex. Convergent Divergent Nozzle flows 2. Supersonic combustion. ex. Reactive flow over cascade cavities, Fuel-air mixing and combustion in High speed flows. 3.Other features such as compressibility effects, multistep reaction, multi blocking, fine grid embedding, unstructured grid etc. Can you please suggest Commercially available CFD code which can perform above listed tasks. Thanking You. Yours sincerely H.S. Muralidhara |
May 13, 1999, 11:19 |
Re: CFD Code
Hello
Please check the website www.metacomptech.com. I believe they meet the requirements you are looking for. We at ICEMCFD ( www.icemcfd.com ) provide the pre and post processing environment along with mesh adaptation. For more info please visit the above websites for more info. |
May 14, 1999, 18:34 |
Re: CFD Code
May 15, 1999, 11:05 |
Re: CFD Code
May 26, 1999, 06:19 |
Re: CFD Code
To link multi-step finite rate reactions with CFD, see http://www.pfd.ie, where PFDReaction is described. This works with both Fluent and CFX and makes a first principles connection between kinetics and multi-scale mixing for up to 50 species and 50 reactions. You can also run a simple simulation on-line, using Net.Re@ction, powered by FLUENT and PFDReaction on an IBM SP2 supercomputer.
Display Modes | |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 13:26 |
CFD Code with Fortran | murat | Main CFD Forum | 0 | October 11, 2009 18:05 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
CFD JOBS and Expected Salary.... | Noel Harrison | Main CFD Forum | 11 | November 22, 2000 08:15 |
Since Last June | John C. Chien | Main CFD Forum | 3 | July 12, 1999 10:38 |
