-   -   Fluid flow in porous material (http://www.cfd-online.com/Forums/main/84472-fluid-flow-porous-material.html)
bjorson January 31, 2011 07:31
Hello, I need advice for the simulation of fluid flow in porous material. Material has a simple block shape. Pore size is 110 μm 220 μm 330 μm 550 μm 1000 μm 1600 mm. Needs to calculate the fluid pressure in the porous materials, and also a graph of pressure. What software is on the simulation of most appropriate? I will be grateful for any idea.
Thank you
trinath2rao January 31, 2011 08:33
Hi bjorson,
I think PORFLOW from ACRi-CFD
will give better simulation in porous media..As This software is specialised in Solving problems involving transient or steady state fluid flow, heat, salinity and mass transport in multi-phase, variably saturated, porous or fractured media with dynamic phase change.
As your problem dealing with fluid flow through pores, fractures . I recommend PORFLOW software.....
For more detail U can check http://www.acricfd.com/
Hope It solves your Problem
