December 15, 2004, 10:20 |
oil/water flow in pipeline
I am working with a problem of oil and water flow in pipelines. I want to simulate the interface between those two fluids and so I thought that the VOF model implemented in FLuent would be Ok . But in fact not, it gives some strange results, and it is not possible to track these instabilities which are going to developped along the pipe (horizontale or inclined). I have read several post about free surface problem . and some of you suggest to use Flow3D. Is it going to work in this case (3d flows in a pipe)?. Do somebody have others advices ?. Thanks for the help Pkt |
December 15, 2004, 10:44 |
Re: oil/water flow in pipeline
Sorry I don't know the answer to your question.
But try www.flow3d.com. You can e-mail them a question - or call them. When I was using the program (10 years ago) I found them to be helpful. Good luck. |
December 15, 2004, 11:00 |
Ok Thanks,
In fact , it is a question about the VOF implementation in different codes . I have read that FOAM is using a VOF too. Any users whom experienced that too ?. Thanks |
December 15, 2004, 11:24 |
Yup, I've done a lot of free surface in FOAM. If you want to see a good example, there is an SAE paper with LES + free surface and a a thesis on air bubbles in water with instability.
Hrv |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 22:08 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
