February 1, 2011, 11:30 |
BC's for stream function equation...
RAJESH.P
Rep Power: 15 |
Sir,
I am using stream-function vorticity formulation for flow over a flat plate problem. I am solving these steady state equations by line-by-line algorithm. for that far away from the plate I have to use a mixed derivative boundary condition ie (mixed derivative of psi wrt both x and y =0) for stream function equation. But in this case i am not able to tackle this bc using fictitious point method. Please help me if anybody know how to apply this bc... |
February 1, 2011, 15:43 |
Andrew
Rep Power: 18 |
you can try v=0 and u=U at that boundary..U is the freestream velocity. Sort of like a symmetry line, but is actually a moving wall ( Fromm 1963 and Fromm and Harlow 1963)
February 1, 2011, 23:19 |
RAJESH.P
Rep Power: 15 |
Thank you for ur reply
But my actual problem is mixed convection heat transfer. So it should give results for both natural and forced convection regimes. For natural convection u and v are zeros. Only possible bc is d^2(psi)/dxdy=0. But I cant apply this Bc directly to discretized stream-function equation. |
February 1, 2011, 23:31 |
Andrew
Rep Power: 18 |
how are you getting u and v to be zero?
February 1, 2011, 23:37 |
RAJESH.P
Rep Power: 15 |
For natural convection occurs due to density change(buoyancy) caused by temperature gradient. therefore far away from the plate this effect is negligible fluid will be at rest both u and v will be zero...
February 2, 2011, 08:45 |
Andrew
Rep Power: 18 |
if you are far enough from the plate free convection should be zero, as you stated and the BC should be driven by the forced convection flow, right? Have you tried to get the flow profile neglecting any free convection?
boundary condition, stream-function, vorticity |
LiencubiclowRemodel | nzy102 | OpenFOAM Bugs | 14 | January 10, 2012 08:53 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Viscosity and the Energy Equation | Rich | Main CFD Forum | 0 | December 16, 2009 14:01 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
