About low Reynolds number airfoil experiment data.
Old   November 16, 2004, 12:34
Default About low Reynolds number airfoil experiment data.
zqnwpu
Hi: i need some low Reynolds number airfoil experiment data to validate my NS code,because i don't know if it is right for low RE flow, Where can I get some experiment data free? I have download some data about airfoil data( as UICC web-site),but there is no free stream Ma no. and temperature, May is there any other methods to test the code? Many advice will be great appreciated !
Old   November 16, 2004, 12:56
Default Re: About low Reynolds number airfoil experiment d
andy
Low Reynolds numbers aerofoil flows are usually low Mach number and isothermal. For such flows the Reynolds number is the only significant parameter. The Mach number is zero and the temperature constant. The thermodynamic state would only affect the size of the (constant) density which is determined via the Reynolds number.
I am curious if you have an application for high Mach number and low Reynolds number aerofoil flows?
Old   November 16, 2004, 13:51
Jarmo Monttinen
What is your Reynolds number?
I would not worry about the FS Mach number, if you have a compressible code, just set it to 0.1 that has been used by others successfully.
You might want to look at: Carmichael, B. H. 1981. Low Reynolds Number Airfoil Survey, Volume 1, Final Report. NASA CR-165803, Langley Research Center.
This will most likely explain why your results do not agree with experimental results.
-- Jarmo
Old   November 16, 2004, 23:19
zqnwpu
Hi, Thanks Jarmo and andy! The Reynolds numer are baseed on the airfoil chord length,maybe 4*10**4,just as Jarmo said, I use a compressible code to simulate the flow field around A18 airfoil,from (http://www.aae.uiuc.edu/m-selig/uiuc...uiuc_lsat.html),the data format reads: ..... Airfoil: A18 Builder: R. Cooney Comment: clean
Number of Reynolds #'s: 7
Average Reynolds #: 40000 Number of angles of attack: 7 alpha / Cl / Cd / S panwise Cd's >>> -1.16 0.117 0.0244 0.0247 0.0203 0.0290 0.93 0.324 0.0202 0.0155 0.0237 0.0253 2.82 0.540 0.0349 0.0363 0.0353 0.0396 5.05 0.842 0.0405 0.0350 0.0401 0.0471 .......... so, if i set Mach=0.1,i steel need the temperature to determine the molecular viscosity ! if i set the temperature to be any value (maybe 289K), is it right? ....in other words ,such setting will not reduce the accuracy of simulating results?
Old   November 17, 2004, 14:54
Jarmo Monttinen
Yes, go ahead and set M=0.1, and T = 288 K or so. This approach will give you a reasonable numerical approach.
But as you can see from the data, the cd varies along the span, so you are not likely to match the results using a 2-D simulation.
-- Jarmo
Old   December 25, 2004, 03:52
Default low Re-number airfoil experimetnt
Jussi Salminen
Do you have any text / data available in pdf form?
Jussi Salminen, R&D Manager, Netma Progress Oy, Lahti Finland.
jussi@netma.fi
Flapping Airfoil Simulation in Low Reynolds Number Flow M.Sc_Student FLUENT 4 April 7, 2010 10:28
plotting drag coefficient in low reynolds number flow past cylinder atmcfd FLUENT 0 January 2, 2010 08:34
Low Reynolds Number Instability in icoFoam - Cavity Case kmooney OpenFOAM Running, Solving & CFD 2 October 8, 2009 14:09
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
DNS -low Reynolds number Airfoils Pat Main CFD Forum 2 January 21, 2005 14:17
