Prandtl Number
Old   October 22, 1999, 10:22
Default Prandtl Number
Thomas P. Abraham
Hello Everyone:
I have a question for you all. Reynolds number tells us about the degree of turbulence, Grashof number about the degree of buoyancy forces, etc.
How about the Prandtl Number? What kind of physics it's telling us?
Thanks,
Thomas
Old   October 22, 1999, 11:37
Default Re: Prandtl Number
Patrick Godon
The Prandtl number measures the relative diffusion rates nu/kappa, where nu is the kinematic viscosity and kappa is the thermal diffusivity. So it gives an estimate of the dominant diffusion process in the flow.
Old   October 22, 1999, 11:57
Default Turbulce Prandtl Number?
sheng
I saw a name "turbulence Prandtl Number". I wonder is the turbulence really can diffuse?
regards,
sheng
Old   October 22, 1999, 14:33
Demselles Hollowajiwoak
Pr=v/a => high Pr=momentum diffusion is dominant
low Pr=thermal diffusion is dominant
Regards Demselles
Old   October 23, 1999, 03:01
Default Re: Reynolds Number???????
Yogesh Talekar
Is it true that Reynolds numbers tells about degree of turbulance? I think it only tells which one of the forces viz. momentum force and viscous force is dominant.
Can anybody explain?
Yogesh
Old   October 23, 1999, 17:56
Default Re: Turbulce Prandtl Number?
Jonas Larsson
The turbulent Prandtl number is the ratio between turbulent diffusivity of momentum and turbulent diffusivity of heat. The turbulent Prandtl number can in many cases be approximated as a constant, although it in reality varies. By assuming a constant turbulent Prandtl number you can estimate the turbulent transport of heat by using the eddy-viscosity computed with a common turbulence model. This is also what most people do, although there exists turbulence models which solve extra transport equations in order to account for the variation. Sometimes you also see models with algebraic formulas for the turbulent Prandtl number.
Old   October 24, 1999, 12:03
Jonas Larsson
Not entirely true, but you can say that the higher Reynolds number you have the more likely it is that you will have a turbulent flow. A higher Re number also gives a larger range of turbulent scales.
Old   October 25, 1999, 09:47
wolfgang schmidt
I don't agree with this aspects. The reynolds-number is just the ratio of two forces. If it's larger than unity it says momentum forces are larger then viscous forces, if it's lower than unity it's vice versa -that's all nothing less and nothing more. Often -but not always- it allows conclusions about the "turbulence intensity" or the amount of energy needed to keep the fluid flowing in the way it does. Depending of the geometry and fluid conditions the change from laminar to turbulent flow may occure at Reynolds Numbers of 2000, or 3000, or even 100000. But this are only rules of the thumb.
Old   October 25, 1999, 10:04
Patrick Godon
Another important aspect of the Reynodls number is related to the boundary layer.
If you have a boundary where a boundary layer can form, then the Reynolds number gives you a first estimate of the size of the boundary layer that will form there.
e.g. if Re is very small (e.g. Re=10) then the boundary layer is relatively large, its size is a significant fraction of the size of the whole domain.
if Re is very large (Re=1000), then the size of the boundary layer is very small indeed, and you need to have a higher resolution close to the boundary.
IN general the size of the boundary layer L is related to the Reynolds number roughly as
L proportional to D/sqrt(Re)
where D is the size of the whole domain.
Old   October 25, 1999, 10:31
Jonas Larsson
Yep, that's exactly what I said ... a larger Re makes it more *likely* to have a turbulent flow. Note the word likely.
Old   February 15, 2011, 10:11
Default what is the range of prandtl number for viscoelastic fluids?
  #11
tayyab
tayyab1986 is on a distinguished road
could it be near to 1 or 2??
i have seen that for viscoelastic polymer ethylene glycol its range is from 16 to 29.
tayyab1986 is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
