dissipative and dispersive error of finite difference methods
Like Tree6Likes
  • 2 Post By cfdnewbie
  • 3 Post By sbaffini
  • 1 Post By FMDenaro
Old   June 21, 2013, 04:29
Default dissipative and dispersive error of finite difference methods
shubiaohewan is on a distinguished road
Hi all,
We know that for the spatial derivative using a finite difference method, if the leading error term is odd, then the results contain dispersive error, while if the leading error term is even, then it has dissipative error.
I want to compare the degree of such errors. Say, the leading error term is 7th order (FD7), compared with the leading error term is 5th order (FD5), which one has more severe dispersive error? For sure, FD7 is more accurate, what's its performance with regard to dispersive error?
Thanks.
Shu
shubiaohewan is offline   Reply With Quote
Old   June 21, 2013, 06:29
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by shubiaohewan View Post
Hi all,
Thanks.
Shu
This is a classical numerical analysis task, you can analyze the local truncation error of the discretization formula, it gives much information about the character of the error.
Furthermore, I suggest using the spectral analysis too, that is the modified wavenumber that each formula produces.
It is important to remark that not necessarily a higher order accurate formula performs better than a lower one on a given grid. Accuracy order is only an asymptotic estimation that does not tell you how the formula behaves for the chosen grid. Thus, the modified wavenumber analysis can help to understand the error distribution for the grid you want to use.
FMDenaro is offline   Reply With Quote
Old   June 21, 2013, 06:31
cfdnewbie
cfdnewbie is on a distinguished road
There is a standard procedure of analysing dispersive and dissipative behavior of FD schemes. Discretize a linear advection equation, plug in a wave with frequency k and amplitude a and check the resulting frequency and amplitude response - that gives you the dissipation and dispersion error of your scheme.
cfdnewbie is offline   Reply With Quote
Old   June 21, 2013, 06:46
Such analysis can be extended, in a suitable way, also for the non linear equation (e.g., Burgers)
Old   June 21, 2013, 07:01
cfdnewbie
Hello Prof. Denaro,
I have only seen this done for linear equations. I assume that Burger's would lead to a non-linear system to solve for? Do you have any good reference on the details of this? that would be a very interesting read!
thanks in advance!
Old   June 21, 2013, 07:15
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I don't know if Prof. Denaro is referencing what i have in mind; however, a possible practical (i.e., non analytical) approach is this:
http://www.sciencedirect.com/science...21999111001148
sbaffini is offline   Reply With Quote
Old   June 21, 2013, 07:20
cfdnewbie
Thank you Paolo,
that looks very interesting!
Old   June 21, 2013, 09:12
yes, there are some papers as this one that in these years analysed the non-linear equations.
We also worked on the wavenumber-based analysis for the one and multi-dimensional non-linear equations, using an analytical/numerical approach
http://onlinelibrary.wiley.com/doi/1...d.179/abstract
http://www.sciencedirect.com/science...21999111000933
cfdnewbie likes this.
