Flotran: Lift and drag
Old   January 18, 2005, 10:27
Default Flotran: Lift and drag
Joe Bystryk
I am trying to calculate the lift and drag on an airfoil using Flotran. I select all the nodes attached to the body. I can then use the 'intsrf, press' command to get the pressure forces on the body. When trying to use 'intsrf, tauw' command I recieve an error message that tauw is not a valid DOF. When trying to add DOF, tauw does not appear as an option. Can anyone help, or suggest a walkthrough of calculating the shrear stresses on an body in an external flow using Flotran? Cheers.
How does FLUENT calculate lift and drag? xTamx420 FLUENT 0 May 30, 2011 13:35
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
lift and drag of 2d airfoil using ANSYS FLOTRAN vinu varghese Main CFD Forum 0 January 11, 2006 04:33
drag and lift coefficient Noé Siemens 5 July 13, 2004 10:21
