February 23, 2011, 01:16 |
Heat transfer through the porous media.
Fairuz Hafizan
Rep Power: 15 |
Hye, actually i would like to know, is there will be temperature drop when the fluid such as air through the porous media such as water? If yes, how i can set the important parameters in porous media?or what else the important which i need to follow? I already create the simple of 2D geometry which is the air was flow through the porous media (10cm) and exit that medium. Actually i was try to simulate but there is not pattern of the temperature drop..
Display Modes | |
heat transfer in porous media | Miko | Siemens | 10 | February 16, 2022 07:13 |
heat transfer to porous media... | club68512 | FLOW-3D | 5 | November 3, 2010 23:20 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
heat transfer with porous media | gokul | FLUENT | 0 | February 24, 2009 13:43 |
REG POROUS MEDIA HEAT TRANSFER | Rashmi Venkat | FLUENT | 6 | June 1, 2006 05:13 |
