-   -   Vorticity magnitude (http://www.cfd-online.com/Forums/main/8567-vorticity-magnitude.html)
CFD-junior January 19, 2005 05:25
Vorticity magnitude
Please could someone tell me how to calculate the vorticity magnitude.
Thanks
ag January 19, 2005 10:04
Re: Vorticity magnitude
Compute the curl of velocity and take the magnitude of the vector.
agg January 20, 2005 14:21
wx = dw/dy - dv/dz wy = du/dz - dw/dx wz = dv/dx - du/dy
w = wx(i) + wy(j) + wz(k)
vorticity magnitude = sqrt(w.w) = sqrt( wx*wx +wy*wy +wz*wz)
w0er January 21, 2005 22:59
Could this function be defined into any cfd post.
la7low August 17, 2011 10:07
or with vorticity tensor
|w|=||wij||
where wij is the vorticity tensor defined as the antysymmetric part of the velocity gradient tensor. Its magnitude defined by:
||wij||=sqrt(2wij*wij)
and its the same as the magnitude of the vorticity vector as defined earlier.
Hanseny March 2, 2016 01:01
Originally Posted by la7low (Post 320482)
|w|=||wij||
If I define a antisymmetric matrix as:
0 x y
-x 0 z = A
-y -z 0
which is similar to Vorticity tensor, but when I calculate A*A, I got
-2*x^2-2*y^2-2*z^2 which is negative and has problem under square root. Could you please tell what causes this problem. Thank you very much.
FMDenaro March 2, 2016 04:33
Originally Posted by Hanseny (Post 587644)
0 x y
-x 0 z = A
-y -z 0
I do not understand what you did ... if you want to define a measure for a matrix, you should define some norm on that ||A||, this is not so simple.
You can define an induced norm by using a (non vanishing) vector x such that
||A.x||/||x||
Hanseny March 2, 2016 07:04
||A.x||/||x||
Thank you for your reply,
Now I know what is the norm of a matrix, then I still have a question:
What is the magnitude of vorticity, seems like it is not equal to the norm
of vorticity tensor. thanks again.
FMDenaro March 2, 2016 07:11
Indeed the vorticity vector must be extractet from the antisymmetric matrix..
