Vorticity magnitude
Like Tree4Likes
  • 1 Post By CFD-junior
  • 1 Post By ag
  • 1 Post By agg
  • 1 Post By la7low
Old   January 19, 2005, 05:25
Default Vorticity magnitude
CFD-junior
Please could someone tell me how to calculate the vorticity magnitude.
Thanks
mohammad_mec87 likes this.
Old   January 19, 2005, 10:04
Default Re: Vorticity magnitude
ag
Compute the curl of velocity and take the magnitude of the vector.
Old   January 20, 2005, 14:21
agg
wx = dw/dy - dv/dz wy = du/dz - dw/dx wz = dv/dx - du/dy
w = wx(i) + wy(j) + wz(k)
vorticity magnitude = sqrt(w.w) = sqrt( wx*wx +wy*wy +wz*wz)
Old   January 21, 2005, 22:59
w0er
Could this function be defined into any cfd post.
Old   August 17, 2011, 11:07
Default or with vorticity tensor
la7low is on a distinguished road
|w|=||wij||
where wij is the vorticity tensor defined as the antysymmetric part of the velocity gradient tensor. Its magnitude defined by:
||wij||=sqrt(2wij*wij)
and its the same as the magnitude of the vorticity vector as defined earlier.
la7low is offline   Reply With Quote
Old   March 2, 2016, 01:01
Hanxun Yao
Hanseny is on a distinguished road
Originally Posted by la7low View Post
|w|=||wij||
If I define a antisymmetric matrix as:
0 x y
-x 0 z = A
-y -z 0
which is similar to Vorticity tensor, but when I calculate A*A, I got
-2*x^2-2*y^2-2*z^2 which is negative and has problem under square root. Could you please tell what causes this problem. Thank you very much.
Hanseny is offline   Reply With Quote
Old   March 2, 2016, 04:33
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Hanseny View Post
0 x y
-x 0 z = A
-y -z 0
I do not understand what you did ... if you want to define a measure for a matrix, you should define some norm on that ||A||, this is not so simple.
You can define an induced norm by using a (non vanishing) vector x such that
||A.x||/||x||
FMDenaro is offline   Reply With Quote
Old   March 2, 2016, 07:04
Hanxun Yao
||A.x||/||x||
Thank you for your reply,
Now I know what is the norm of a matrix, then I still have a question:
What is the magnitude of vorticity, seems like it is not equal to the norm
of vorticity tensor. thanks again.
Old   March 2, 2016, 07:11
Indeed the vorticity vector must be extractet from the antisymmetric matrix..
Old   October 8, 2021, 02:49
Default Vorticity magnitude in Fluent
Shuvam Mohanty
mohanty.shuvam4 is on a distinguished road
By definition, vorticity is a pseudovector field that describes the local spinning motion of a continuum near some point (the tendency of something to rotate. In FLUENT is given by: dY-Velocity/dx minus dX-Velocity/dy.
To plot contours for this function using FLUENT go to the "Define" menu, pick "Custom Field Function". Then in the "Field Functions" drop-down box, pick "Derivatives", select "dY-Velocity/dx" from the second drop-down box, click "Select", then the "-" button, then select "dX-Velocity/dy " and click "Select".
Now choose a name for your new variable ("Vorticity-magnitude"), then click "Define".
When you go to plot contours, choose "custom field function" and then your variable will pop up there.
mohanty.shuvam4 is offline   Reply With Quote
Old   October 8, 2021, 04:42
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
I don't know why someone decided to necrobump this thread but if we're talking about Fluent...
Fluent already has a built-in field for vorticity (going back for as long as I can remember). You don't need to do all this custom field functions business. It's readily available. Just click it :4head:
LuckyTran is offline   Reply With Quote
Vorticity magnitude makaero FLUENT 0 May 25, 2011 21:30
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
magnitude of vorticity using fluent ryan Main CFD Forum 1 November 30, 2009 17:29
Could vorticity magnitude be ploted ? w0er Main CFD Forum 4 February 8, 2005 08:49
Vorticity magnitude Hernani Siemens 2 August 20, 2001 10:48
