Derivation by spectral method
Old   January 19, 2005, 16:50
Default Derivation by spectral method
daniel
I want to evaluate the derivative of a function f=f(x) periodical, by a spectral method. Let's say
(1) f(j)=1/N*SUM(with k=from 1 to N)
( Ck*exp(-i*2pi*(k-1)*(j-1)/N )
where j= index of point N= number of points k is the wave number f is the fundamental frequency N is the number of points Ck are the spectral coefficients
The (1) is the Discrete Fourier decomposition. Now, I calculate the Ck coefficients by the inverse trasformation and I can use the (1) to re-build my function. At the same time I can use the Ck to calculate the derivative of the expression (1), which should be:
(2) df(j)=1/N*SUM(with k=from 1 to N) (-i*2*pi*(k-1)*Ck/(N*DX))*exp(-i*2pi*(k-1)*(j-1)/N )
where DX is the sample. What happens to me is that The re-built function is correct, but not the derivative! Do you have any hint?
Old   February 1, 2005, 22:39
Default Re: Derivation by spectral method
BradAeroHead
Looks like you're trying to take the derivative with respect to x, where x_j = (j-1)/N. So, you are adding an unneeded factor 1/N*DX in your derivative.
Also, shouldn't you be using negative k values as well, like k=-N/2,...,N/2-1 ?
Vortex method vs Spectral synthesizer for LES HS FLUENT 1 February 14, 2017 02:46
Spectral (finite) volume method Max Main CFD Forum 1 April 13, 2006 11:11
some thing about the spectral method ztdep Main CFD Forum 3 February 16, 2006 14:44
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 18:28
Spectral Method Boundary condition Deepak Main CFD Forum 1 February 25, 2004 09:48
