Relation Between Wind Tunnel and CFD
Old   March 3, 2011, 01:27
Default Relation Between Wind Tunnel and CFD
dido is on a distinguished road
Hello everyone,
Can someone please tell me why still use wind tunnel when CFD is already exist?
Is it because of large memory needed of its large mesh?
Thanks in advance
Dido
dido is offline   Reply With Quote
Old   March 3, 2011, 02:10
Skeptic
Lysistrata is on a distinguished road
Originally Posted by dido View Post
Hello everyone,
Thanks in advance
Dido
I would say it is because CFD is unreliable and not properly validated for many applications.
Lysistrata is offline   Reply With Quote
Old   March 3, 2011, 10:55
Default CFD + Wind Tunnel = Complimentary Relationship
gocarts's Avatar
Richard Smith
gocarts is on a distinguished road
"To many observers the rivalry between wind tunnels and Computational Fluid Dynamics (CFD) is a zero-sum game - as CFD matures it simply replaces wind tunnels. However, this is far from the truth. Often you'll find wind tunnels and CFD used together in a symbiotic process where one technique fills in knowledge gaps left by the other." For more try:
http://www.symscape.com/blog/wind-tunnels-and-cfd
CFD is only unreliable when you don't benchmark (calibrate) - agreed. However, the same principle applies to wind tunnels when you don't benchmark too. So without benchmarking most modeling (physical or virtual) is unreliable. For more try:
http://www.symscape.com/blog/lessons...fluid-dynamics
Full Disclosure: I authored both articles I linked to above.
Symscape, Computational Fluid Dynamics for all
gocarts is offline   Reply With Quote
Old   March 3, 2011, 12:51
Skeptic
Originally Posted by gocarts View Post
" However, this is far from the truth. Often you'll find wind tunnels and CFD used together in a symbiotic process where one technique fills in knowledge gaps left by the other." For more try:
I understand and agree with what you are trying to say, but "symbiotic" is a bit twee.
That's not the only time CFD is unreliable.
Many CFD codes (not necessarily the under-lying mathematics or assumed physics) fail to pass what some would regard as essential scientific tests, e.g. reproducibility of results by different, unbiased experimenters.
Old   March 3, 2011, 23:19
L.Y LIN
iilw1314 is on a distinguished road
if there are tow results before the goverment officer who make important decision,one is from wind tunnel,the other is from CFD,he will choose the former.
iilw1314 is offline   Reply With Quote
Old   March 4, 2011, 18:18
Martin Hegedus
Martin Hegedus is on a distinguished road
When both are well done, I'll trust wind tunnel over CFD. I'd use wind tunnel to calibrate CFD, I would almost never use CFD to calibrate a wind tunnel.
Why does CFD hava an issue? Turbulence and turbulence models. For example, only the highest fidelity CFD runs can capture transition from laminar to turbulent, and that is for academic problems. Another example, most people use RANS solvers. The turbulence models are just models. They create eddy viscosity in an effort to model turbulence. The eddy viscosity can be hundreds of thousands times larger than the laminar viscosity term in the NS equations. So basically all that is being done is to throw gobs of viscosity at a problem to model turbulence.
Of course CFD has it's place in the design cycle. It helps engineers explore a problem, come up with preliminary designs, and get the best value out of wind tunnel runs. Wind tunnel runs can be very expensive and time consuming. I believe in the need for CFD since I write CFD codes.
Wind tunnel tests have their issues too. For example modeling flight Reynolds numbers and transonic flow. But I don't necessarily trust CFD to model flight conditions either. For example, it is very hard to model gaps in geometries, such as those that occur around flaps, slats, and ailerons. The reason is both griding and physics. Many times those gaps are fared over in CFD.
Here is a link to a problem where a RANS solver can give you two answers, depending on how the problem is converged, and neither one of them is correct.
http://www.hegedusaero.com/examples/...eShoulder.html
Martin Hegedus is offline   Reply With Quote
how to consider perforated wind tunnel wall in CFD simulation littlelz CFX 4 June 11, 2009 05:51
Comparing wind tunnel tests costs with CFD Freeman Main CFD Forum 9 January 30, 2006 08:02
CFD in wind tunnel Anders Hagberg Main CFD Forum 9 June 1, 2004 17:42
CFD versus Wind Tunnel Test wuttichai Main CFD Forum 3 November 12, 2003 00:07
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
