-   -   How can I use Q-criterion to visualize vortex? (http://www.cfd-online.com/Forums/main/85718-how-can-i-use-q-criterion-visualize-vortex.html)
hadesmajesty March 5, 2011 03:31
I am simulating incompressible boundary layer transition flow. I separate the flow velocity (u, v, w) into a base flow part (U, V, W) and a disturbance part (u ,v ,w,). I use the below equations to calculate Q (second invariant of velocity gradient tensor):
Ω= (0.5*{dudy}-0.5*{dvdx})**2+(0.5*{dudz}-0.5*{dwdx})**2+
(0.5*{dvdx}-0.5*{dudy})**2+(0.5*{dvdz}-0.5*{dwdy})**2+
(0.5*{dwdx}-0.5*{dudz})**2+(0.5*{dwdy}-0.5*{dvdz})**2
S={dudx}**2+(0.5*{dvdx}+0.5*{dudy})**2+(0.5*{dwdx} +0.5*{dudz})**2+
(0.5*{dvdx}+0.5*{dudy})**2+{dvdy}**2+(0.5*{dwdy}+0 .5*{dvdz})**2 +
(0.5*{dwdx}+0.5*{dudz})**2+(0.5*{dwdy}+0.5*{dvdz}) **2+{dwdz}**2
Q=0.5*(Ω-S)
My questions are:
(1) In the calculation of velocity gradient tensor, should I use the total flow or disturbance flow quantities?
(2) I have tried both in (1), but the values of dudx is around 1.0e2 pre second in the transition region and the final Q is around 1.0e5 or larger. Are these values normal? In the papers I read, Q are usually closed to zero about 1.0e-2.
(3) I am using very coarse grid in my simulation (820*80*16 for streamwise, wall-normal and spanwise direction) and I cannot see vortical structures, for example, a ring at the tip and two long legs at the tail as the papers. Is that because of my resolution?
Thank you in advance.
Atze March 5, 2011 04:57
I can't understand your notation very well, sorry, but i usually write Q=0.5*(Ω^2-S^2) where Ω is the vorticity magnitude and S the mean strain rate (absolute quantities)
I use the normalized Q-criterion, so the range is -1<Q<1
Hope be helpful
hadesmajesty March 6, 2011 03:31
Thanks a lot. After normalization the result looks better.
