Rotor 67 full compressor geometry
Old   January 24, 2005, 06:59
Default Rotor 67 full compressor geometry
jf
I'm searching the full 3-D blade geometry of the 2-stage rotor 67 compressor. Or more exactly the full 3-D geometry ot the 2-stage compressor from which the famous rotor 67 has been extracted.
I have the full 3-D blade geometry (in x,r,theta coordinates) of the rotor only. I found it in Strazisar et al. (NASA-TP-2879).
I've been unable to find the same kind of data for the full compressor. I've ordered 2 technical reports from the NASA but the geometry is given with a "throughflow mind" (that is the camber angle at the leading and trailing edge, the maximum thickness). The 2 technical reports are the following :
- NASA TP 1314 : Design and Performance of a 427 -Meter-Per-Second-Tip-Speed Two-Stage Fan Having a 2.40 Pressure Ratio
- NASA TP 1493 : Performance of Two-Stage Fan Having Low-Aspect-ratio, First-Stage Rotor Blading.
Is there another technical report from the NASA that gives the full 3D geometry (in x,r,theta coordinates) ?
Do you know another way to get these informations ?
Thanks in advance
Old   May 26, 2015, 10:48
sagar
sagarparikh31 is on a distinguished road
Do you have the co-ordinates for the paper "Design and Performance of a 427 -Meter-Per-Second-Tip-Speed Two-Stage Fan Having a 2.40 Pressure Ratio". I have already got the paper but I want the coordinates or any program by means of which I can extract coodinates.
thank you in advance
Regards,
Sagar
sagarparikh31 is offline   Reply With Quote
Old   November 22, 2019, 19:08
breno H
brenohc is on a distinguished road
Hi, would you have the coordinates for rotor 67?
brenohc is offline   Reply With Quote
Old   January 28, 2024, 05:14
raju
rajkumar234 is on a distinguished road
hi all
i need 3d geometry of NASA,s R 67 compressor blade
which will be comatibel with ansys workbench
if anyone has can u plese provide it on here or on my mail id
vijay005079@gmail.com
it will mean alot
thakyou
regards
rajkumar
rajkumar234 is offline   Reply With Quote
from single passage to full annulus c120613 CFX 0 May 4, 2011 10:16
full multicomp DIFF? jdb FLUENT 0 May 11, 2005 21:58
Full Buoyancy model Swapnil CFX 2 April 30, 2003 08:54
Full System Solution Provider? Donald Casteel Main CFD Forum 0 April 13, 2003 12:44
How to model a full 3-D cylinder in cfx44? S. Ding CFX 1 June 26, 2002 11:32
