supersonic mixing : boundary condition
Old   January 28, 2005, 15:44
Default supersonic mixing : boundary condition
amol palekar
I am doing a 3d simulation of a mixing problem where a sonic jet is injected into supersonic crossflow. I am using second order extrapolation boundary condition at the exit. But I am getting negative densities at the exit boundary condition. Any suggesations ? Amol
Old   January 28, 2005, 15:50
Default Re: supersonic mixing : boundary condition
Runge_Kutta
Is the wall normal velocity into the domain or out? Is the wall normal velocity subsonic or supersonic?
What is your intent for the boundary? Do you want a nonreflecting boundary, a force free boundary, or maybe one where some quantities are fixed?
Old   January 28, 2005, 16:17
amol palekar
I guess the earlier discription was very short. so this:
A a sonic (Mach 1) jet is injected into a constant area duct. The crossflow (flowing across the duct) is of Mach 2. I am having trouble at the exit boundary where flow leaves the computational domain. Right now I am doing a inviscid mode simulation and hence the velocity normal to exit boundary is supersonic. But in practise, the flow at the exit will be a supersonic boundary layer having both subsonic and supersonic layers. My intent for the boundary is to have a smaller computational domain. THanks for the reply Runge_Kutta (cool name).
Old   January 28, 2005, 17:12
Runge_Kutta
For outflow boundaries one should specify this number of boundary conditions:
Euler Subsonic: 1
Euler Supersonic: 0
Navier-Stokes Subsonic: N_dim + 2 + (N_species - 1)
Navier Stokes Supersonic: N_dim + 1 + (N_species - 1)
where N_dim is the number of dimensions in your simulations and N_species is the number of species in for which you are solving a species equation. Take each boundary grid point on a point by point basis and classify it as inflow/outflow, subsonic/supersonic. Next, be careful about Euler boundaries in a Navier-Stokes calculation (things like inviscid slip walls). Right now, you are not permitted to impose any BCs for an Euler supersonic outflow. That will change when you add diffusive terms.
Old   January 28, 2005, 17:16
amol palekar
I am using a commercial code for the simulation and I have to use the boundary conditions avilable with software. The list is at : http://www.aerosft.com/Gasp/Manual/reference/x1885.html
The most relevant boundary condition I found was extrapolation from within the cell. Thanks a lot for the help.
Old   January 28, 2005, 17:32
Runge_Kutta
First, you and GASP aren't talking to each other. It sounds like GASP isn't interested in Euler flows. Maybe you should presume that all is Navier-Stokes and proceed accordingly.
Navier Stokes - Supersonic outflow :
All wall-normal components of the viscous stress tensor = 0. (n dot tau = 0)
The wall normal heat flux is zero (n dot q = 0)
All wall normal species diffusion velocities are zero.
Navier Stokes - Subsonic outflow :
Both tangential wall-normal components of the viscous stress tensor = 0. (n dot tau dot t1 = n dot tau dot t2 = 0) where t1 and t2 are two tangential unit vectors to the surface.
The last BC is usually specified based on nonreflection criteria.
Old   January 28, 2005, 18:20
amol palekar
Thanks a lot.
Old   January 28, 2005, 20:00
Default experimental data on bed to wall heat tranfer
Rahel Yusuf
Hi Everybody
I am looking for experimental data on bed to wall heat transfer in bubbling fluidized beds. Could anyone cite some references.
rahel
Wind turbine simulation Saturn CFX 58 July 3, 2020 02:13
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
outlet boundary condition Nina Schiepel CFX 2 July 12, 2008 16:27
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 07:40
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 11:06
