March 14, 2011, 14:59 |
Convergence Question
Ryan
Rep Power: 15 |
I am running an alpha sweep on a serrated leading edge wing (top view attached entitled "Wing"). Basically setting the wing at varying angles of attack with respect to the free stream in order to obtain lift and drag coefficients. However the simulation was having trouble converging at a low value and i'm wondering if anybody can comment on why this is and/or how to ensure it converges lower.
The simulation is run at a Reynold's Number of 3 million and the number of cells are listed on each picture with the Spalart-Allmaras as my turbulence model. You can see that as cell density increases, some of the residuals smooth out but they don't drop more than three orders of magnitude. The flow domain, as shown in "Slide1" is divided into a higher density region (Body#1) surrounding the Wing and a lower density region (Body#2) in the outer region. This simulation is in Star-CCM+ but i'm hoping this question about residuals and convergence is generic enough to apply to CFD as a whole. I would also like to avoid playing with under-relaxation values in order to ensure accuracy. |
March 14, 2011, 20:54 |
Martin Hegedus
Rep Power: 19 |
Where is your maximum residual error occurring?
March 14, 2011, 22:07 |
#3 | |
Raashid Baig
Rep Power: 16 |
Convergence Question | James | FLUENT | 2 | October 29, 2005 14:59 |
Question about convergence criteria? | Thomas | FLUENT | 7 | April 8, 2005 19:38 |
help! cyclone convergence question | Lcw | FLUENT | 1 | January 26, 2005 15:29 |
Convergence to 0.001? | Sheng | Main CFD Forum | 20 | March 28, 2000 10:09 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 13:43 |
