Non-Reflecting B.C. in NSC2KE
Old   May 27, 1999, 07:53
Default Non-Reflecting B.C. in NSC2KE
Zou Chu
I has used unstructured FVM public code NSC2KE to simulate a traveling shock of Ms=1.5 (actually I used 2D grid to simulate 1D shock ),the outflow B.C. used NSC2KE's Steger-Warming method . So this problem is a subsonic problem and post-shock mach number < 1 . Before the shock went out of outflow B.C. the result is very good , but when the shock went out my result is very poor because the B.C. reflecting was so big that there was a density and pressure down.
Then I used Thompson's non-reflecting B.C. , but the result is also poor .Could anyone help me to deal with the outgoing boundary conditions ?
Thanks.
Old   May 27, 1999, 09:45
Default Re: Non-Reflecting B.C. in NSC2KE
Patrick Godon
May I suggest you to read the discussion Oleg and I had yesterday on 'BC problem'. It treats boundary conditions through the method of Characteristics. Let me know if you need more details and/or references to the litterature.
Cheers, PG.
Old   May 27, 1999, 21:26
ZouChu
Thanks for your help !
The problem has been solved by Thompson's non-reflecting B.C. (J.C.P 68,1-24,1987) using a characteristic method . I made a foolish mistake so the result is poor because I didn't convert the primitive form to conservative form . Now everything is good for subsonic and supersonic , although there is a little reflection about the most one persent and I should put this B.C. to un-regular geometry .
Confusion between 'non-slip' and 'slip' B.C jinwon park Main CFD Forum 7 March 6, 2008 04:56
Non Reflecting B.C. Alshroof CFX 2 July 31, 2007 20:34
how to set such B.C. in Fluent? Sherri FLUENT 1 January 12, 2006 12:32
Urgent! Help on UDF to set B.C. of 3rd type Ray Hong FLUENT 0 December 28, 2005 19:35
How to set B.C. of the 2nd or 3rd type in UDS? Ray Hong FLUENT 0 December 28, 2005 06:03
