Display trouble with open foam
Old   March 17, 2011, 10:06
Default Display trouble with open foam
L1011 is on a distinguished road
Dear all,
I've recently installed tecplot360 on a new linux 64bit desktop but I encounter display troubles when using it. More precisely, the background of the window is transparent (instead of the usual grey) and I can not see texts nor numbers (for example on legends or axis).
Does anybody already experienced something similar?
Thank you in advance!
L1011
L1011 is offline   Reply With Quote
Old   April 15, 2011, 15:22
In case somebody encounters the same issue, this is what you should do:
  1. Install the latest (2010) version of tecplot
  2. disable the display effects in the Linux's parameters
L1011
Old   April 15, 2011, 19:43
Default Tecplot knowlegde base links
Scott Rumage
scott_rumage is on a distinguished road
For future reference the Tecplot knowledge base has some additional details on this subject.
I searched on "display" under the "linux" category and got several hits:
Here are a couple:
http://kb.tecplottalk.com/products/t...lems-on-linux/
http://kb.tecplottalk.com/products/t...nux-platforms/
Scott
scott_rumage is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
