help in external aerodynamics(which tubulence model is best)
hello sir
i am sathish(student) doing project in external aerodynamics 1) can u tell me which turbulence model is best for solving external aerodynamics 2)whether it is necessary to run k-e model before running any turbulence model.if yes why? |
1)It totally depend on the kind of physics involved (there is no fixed answer for this), the mach number etc. Please provide more details about the kind of problem you are trying to solve. 2) No it is not necessary to run k-e before using any other turbulence model. |
thank you sir
actually i am doing project in xperimental and numerical verification of a commercial car body(i ve taken honda accord)scale 1:14 for this i ve to find cd value.so i asked help in choosing turbulence model |
Take a look at http://www.cfd-online.com/Wiki/Ahmed_body which is a good case for validation of vehicle aerodynamics. Read some papers related to it. What mach number are you targeting ? My guess is SST turbulence model may suit your requirements. |
thanku sir
its not mach no. i am targetting cd value now its coming around 0.22 but i have to bring it to 0.3 so that it will be near to actual
Not sure if I understand this correctly.
Do you have experimental results for a 1:14 scale car? It sounds like this is the case. I assume Cd=0.3 comes from this experiment. Can you show us a picture or two of your experimental setup? Do you have experimental results for a full scale car? Are you running CFD for the scaled and full scale car? I assume Cd=0.22 is for the scaled down car. I also assume you are matching the Reynolds number for the scaled down car. Can you show us a picture of the contours of V/Vinf for your CFD? Is your ground plane moving (or not) for both the experiment and numerical results? I'm assuming that the car is placed on the ground. In this case the ground plane for the experiment MUST be moving at the same speed as the on coming wind. Otherwise, there will be a boundary layer from the floor. If there is a B.L. from the floor, you will need to model that in your CFD run. Not easy, unless you know the profile. What is your Reynolds number based on the length of the car? I'm not very knowledgeable in car aerodynamics, but I assume that a majority of your drag is coming from base drag. (This is something you can check with your CFD run) Base drag includes your back window, if separation occurs over it. At these lower Reynolds numbers, Cd could be sensitive to Reynolds number. In the experiment did you trip the boundary layer at the leading edge of the car? If the car was smooth, and the flow was laminar up to your back window, then the base drag from your experiment would be higher than the base drag for a fully turbulent CFD run. |
i dont ve full car reading...
i ve only for scaled down model it is considered as ground for both experimental and cfd presently i ve taken only for the drag and lift values from the experiment.. pressure i need to take after making arrangemens |
What is your Reynolds number and did you trip the boundary layer in the experiment? |
I got the best results |
OK, I measured my car, it is approximately 15 ft. It is not a Honda Accord. Assuming I'm traveling at 60 m/hr (sorry, I'm in US, so English units). That comes out to a Reynolds number of about 8.4e6. That's turbulent. However, if I'm at 1/14 scale traveling at 60 m/hr then my Re number would be 6.0e5. That is in the laminar/transition region. If the B.L. did not get tripped then a fully turbulent turbulence model will under predict the drag from the backside separated region.
to martin hegedus
it is fixed for both
reynolds i am getting 2.3xe5 |
to martin
i built one platform which is like road and i fitted that to the test cross section
