Supercritical steam flow through orifice (/nozzle)
Old   June 22, 1999, 08:40
Default Supercritical steam flow through orifice (/nozzle)
Miqu Lehtinen
Hi there!
I'm a M.Sc. student and CFD is not my special area. Anyway, I would need some information (article, book, equation, advices...) how to calculate the mass flow rate of supercritical steam (or another liquid) through orifice, restriction or/and nozzle. Or is it possible to use equations for liquid flow or a real gas flow? Pressure ratio would be less or equal to critical.
Thanks for your help!!
Old   June 22, 1999, 13:43
Default Re: Supercritical steam flow through orifice (/nozzle)
Md. Ziaul Islam
I would recommend you to use conservation of mass, momentum and energy equations for one-dimentional nozzle flows. You can try to use JANAF thermochemical tables to calculate enthalpy. Enthalpy is a function of temperature. So if you can write first or second order polynomial equations for enthalpy as a function of temperature using regression analysis or other statistical analysis and can use these equations in your problem. Good luck.
Steam flow modelling-any suggestions please sar_mech Main CFD Forum 0 December 21, 2010 11:29
lenght and number of nodes for an orifice meter flow problem - k-eps model fofo FLUENT 0 November 15, 2009 03:49
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
