May 28, 1999, 11:49 |
Question about Low Re turbulence modelling.
Hi! Friends. I had implemented the Chien's low Re Number Turbulence Modelling . But I had a problme to calculate the dimensionless distance, y+. y+ is generally expressed in the following form. y+ = u* y/nu In above expression, friction velocity, u* ,is equal to sqrt(tau_w / rho ). What is the concrete definition of tau_w ? Would you like to inform me the implementation method of tau_w? For example, as laminar flow, does tau_w have only the form, mu (partial U /partial y)? Is it right?
Thank you. |
May 28, 1999, 19:29 |
Re: Question about Low Re turbulence modelling.
y+ is the same for the Low K-e model as it is for the standard K-e model:
y+ = (((density^2 * Cmu^(1/2) * K)^(1/2))/viscosity) * (distance from wall) where Cmu is the constant 0.09 and K is the kinetic energy. Remember that you need a very fine mesh at the wall for the low K-e model, usually with y+ < 1. David Creech CFD Literature CFX User Subroutine Archive |
Display Modes | |
paper request for lien cubic low Re and lien leschziner low re turbulence model | romant | OpenFOAM | 4 | February 2, 2017 09:52 |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
Low Reynolds Turbulence | Roxy | Siemens | 4 | November 2, 2011 09:00 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
