Heat Transfer & Boundary Conditions across 2D wall
Old   February 6, 2005, 14:42
Default Heat Transfer & Boundary Conditions across 2D wall
SAAD
Hi; i am facing problems in 2D heat transfer.
In 2D, how to model heat transfer across the wall.
what would be the boundary conditions, if convection is taking place on both sides.I dont want to define any fixed temperature on the wall. Through convection, temperature should be defined automatically on the wall.
if anyone can help me on this
regards; Saad
Old   February 6, 2005, 22:40
Default Re: Heat Transfer & Boundary Conditions across 2D
pkm
any standard text book on heat transfer
Old   February 7, 2005, 09:21
SAAD
I know theoratically what is hapenning across the wall. but i am not able to apply theoratical concepts exactly in fluent. I am facing problems in 'BOUNDARY CONDITIONS".
any input would be appreciated
Old   February 8, 2005, 06:04
diaw
Once you have defined the cells that belong to a particular boundary, then apply the b/c of choice.
Fixed flux boundary condition, or alternatively a heat-transfer resistance/temperature combination.
Check on your package... you could even go in & alter the user-defined boundary conditions... all depends on the package you are using.
diaw...
Old   February 14, 2005, 05:23
Daizy
1. what is boundary condition? 2. how many boundary condition do we need to specify for a two dimentional heat transfer problem? 3. how is boundary condition on an insulated surface expressed mathematically? 4. what is the one-dimentional transient heat conduction equation for a plane wall with constant thermal conductivity and heat generation in its simplest form, and indicate what each variable represents.
Old   February 15, 2005, 21:09
diaw
Sounds like you may need to brush up on your basics a little...
Read a few good books... Check out the links page...
diaw...
Old   March 13, 2005, 12:42
gdgsdg
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Heat transfer @ wall boundary AlessandroD CFX 0 August 18, 2009 06:09
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Conjugate heat transfer (vs) periodic boundary mp FLUENT 1 January 13, 2003 01:38
