July 30, 2011, 10:02 |
Lax-Friedrichs flux
aaaaaaaaaaaaaa
Rep Power: 15 |
Have anyone a paper which explain how lax-friedrich(approximate riemann solver) is derived?
Also if we suppose that (u+) is the values of a volume , (u-) the values of neighbour volumes and F the flux then the lax-friedrichs flux gives: F=0.5*( (F+) + (F-) ) - a*( (u-) - (u+) ) This is applied by all faces of a initial volume regardless of its outward unit vector? |
July 30, 2011, 12:45 |
cfdnewbie
Rep Power: 20 |
There's nothing too fancy about the LF-flux....its the average, penalized by the jump to add a strong dissipative constant.... not sure about the original paper, anybody has a hint???
you compute your F by the formula given above, and then do int (F*n) dx to take the normal into account... hope this helps a bit! |
July 30, 2011, 17:09 |
aaaaaaaaaaaaaa
Rep Power: 15 |
Yes , sure. The third term is the dissipative term. Simply , i did not know if it has a complex theory under of it (due to appearance of eigenvectors as dissipative multiplier). With other words, i want to learn what assumptions do for to solve approximate the Riemann problem and finally result at this simply relation.
For other cases as HLLC or HLL there is a assumption on a number of waves. Here? |
July 31, 2011, 03:52 |
cfdnewbie
Rep Power: 20 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Problem setting with chtmultiregionFoam | Antonin | OpenFOAM | 10 | April 24, 2012 09:50 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
Lax Friedrichs Flux Splitting | srikant srinivasan | Main CFD Forum | 1 | February 16, 2001 09:12 |
