turbulence model simulation in unsteady flow
Old   February 4, 2005, 19:46
Default turbulence model simulation in unsteady flow
Chang
Hello~ I have simulated unsteady flow with various turbulence models(RANS). In two equations models case, the solution sometimes converges to steady state. I heard that this phenomenon is to dissipative characteristics of two-equation model. Actually I don't know this meaning exactly. Could you explain more detail to me ??
Is this related to the stagnation point anomaly called by Durbin.
Thanks in advance
Best regards
Old   February 6, 2005, 03:12
Default Re: turbulence model simulation in unsteady flow
yaghoub
Old   February 12, 2005, 06:28
dd
I did many tests and the model RANS which seems to me most effective to reproduce the unsteady behavior of a flow would be model SST. dd nvs
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 10:54
