problem about running gerris
Dear all:
I have successfully installed the Gerris on my ubuntu 10.10 system. When i run program, it was usually terminated by \"/tmp/gfs3tesOV: 1: convert: not found\". Then, i think to created a folder \"/tmp/gfs3tesOV\" and run again. Usually, after some times, we can fix the situation. i wonder if there is a smarter solution. EX: A@A-Workstation:~/Gerrisex$ gerris2D cylinder.gfs ... Approximate projection niter: 1 residual.bias: 6.473e-06 -4.639e-07 residual.first: 4.749e-05 3.828e-06 12 residual.second: 1.210e-04 6.062e-06 20 residual.infty: 2.109e-03 6.354e-05 33 step: 1650 t: 15.00000000 dt: 9.112460e-03 cpu: 372.89000000 real: 377.32398700 Balance summary: 1 PE domain min: 20982 avg: 20982 | 0 max: 20982 MAC projection before after rate niter: 2 residual.bias: 5.365e-07 2.401e-06 residual.first: 3.146e-05 3.431e-06 3 residual.second: 1.109e-04 1.267e-05 3 residual.infty: 3.209e-03 1.882e-04 4.1 Approximate projection niter: 1 residual.bias: 6.561e-07 -1.977e-06 residual.first: 5.412e-05 4.882e-06 11 residual.second: 1.437e-04 1.098e-05 13 residual.infty: 2.704e-03 1.214e-04 22 ... /tmp/gfsid5e1f: 1: convert: not found so how can i do ? thanks |
