Droplet diameter
Hi everybody!
I'am working on the spread of a fire in a close room. This fire begin by a spray. After some researches, I find that the main parameter of the spread of the spray is the initial droplet diameter. So, I'm seaching a way to calculate it and I don't find something relevant. So I'm asking if you have some leads that could allows me to determinate it? Thank you Maxime |
Look for work in the 70's and 80's by P. J. O'Rourke at Los Alamos and Princeton.
Also, The KIVA series of CFD codes for IC Engine simulation - including spray fuel injection - has models for the injector spray. I think the University of Wisconsin maintains these codes now. Good luck! |
Thanks for replying my post! :)
I checked your lead, and I think I should find something. The main problem is to determinate tne initial diameter but I found a document explaining that... more or less. http://books.google.fr/books?hl=fr&l...page&q&f=false If someone has the same problem! If you have other leads do not hesite to tell me! :D Thank you again |
