How important is clean geometry for CFD?
Old   April 9, 2011, 18:03
Question How important is clean geometry for CFD?
Vertex Wrangler
Kevin De Smet is on a distinguished road
I am well aware of the importance of a clean topological model when it comes to performing FEA analyses, because the mesher really has a tough time with tiny faces and short edges and other such guck.
Since CFD has more of a grid approach to discretization, does it matter as much if your geometry is clean or not?
Does it also 'mesh' the model similar to finite elements or are finite difference/volume methods working entirely different? What about a solution that takes into account heat conduction in solids as well, what about then?
Kevin De Smet is offline   Reply With Quote
Old   April 10, 2011, 01:48
Raashid Baig
cfd_newbie is on a distinguished road
Yes it does matter a lot in CFD weather your geometry is clean or not. It wil have big problems since you create a very detailed volume mesh and if your geometry has some bad feature(small extrusions holes, non water tight geometries) you will not only have a tough time meshing, but also solving the simulations.
cfd_newbie is offline   Reply With Quote
Old   April 10, 2011, 09:48
minger is on a distinguished road
In my experience having a clean geometry is crucial. Without a clean geometry it is very difficult to obtain a quality mesh without some of the bad things that were mentioned in the post above.
Having those "bad things" can lead to divergence in your simulations, lack of proper convergence or poor results in those areas.
minger is offline   Reply With Quote
Old   April 11, 2011, 19:05
Dan
DBFIU is on a distinguished road
Bad geometry is a recipe for disaster in every way.
If you have bad geometry, chances are something got messed up somewhere and no one wants to take the time to fix it. It is frustrating, but it has to be done or else you'll shoot yourself trying to debug your mesh and solutions.
The question is, why WOULD you begin any type of simulation with corrupt geometry? If it's a time thing, then just be patient and fix it... you'll be better off in the end.
DBFIU is offline   Reply With Quote
Old   April 12, 2011, 13:28
Vertex Wrangler
Glad to hear it, I'm a proponent of clean models myself. Not only for the repercussions a dirty model can have - just seeing nasty topology makes me just go crazy and I want to fix it! Whether it would make any deal or not.
Old   April 13, 2011, 10:48
pritish
pritish is an unknown quantity at this point
i can tell you...it takes double the time or more to debug a volume mesh....so have it cleaned before that ! ! !
Pritish
F1 freak
pritish is offline   Reply With Quote
Old   April 13, 2011, 10:52
Pauli
Pauli is on a distinguished road
Originally Posted by DBFIU View Post
... why WOULD you begin any type of simulation with corrupt geometry? ...
Because it is the only thing available! Which leaves you the analyst in the position where you can clean it, wrap it, or recreate it. What works best is wholly problem dependent. Operator experience can pay serious dividends.
The other option is to throw your hands up & complain the CAD data is unusable. Since your customer likely won't want to recreate the CAD data, you run the risk of losing business to someone who will work through bad CAD data.
Pauli is offline   Reply With Quote
Old   April 13, 2011, 20:44
Dan
Every analyst should have medium to high experience with CAD for this very reason. No reason to throw your hands up if the geometry is corrupt, just correct it and move on.
discretization, mesh, topology
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
GAMBIT, CAD import, clean up geometry problem Nuray Kayakol FLUENT 1 December 30, 2007 11:43
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
