trouble: F(y) function in external layer of Baldwin-Lomax model |
April 15, 2011, 09:22 |
Nikolay Vinnichenko
Rep Power: 15 |
Hello!
I'm trying to verify my code with Baldwin-Lomax turbulence model for the most simple problem: flat plate boundary layer. I set Reihardt turbulent boundary layer profile as initial condition for velocity and calculate once (before time steps) turbulent viscosity. Surprisingly, I get very low values according to external layer formula. Indeed, it is only 1.7 of molecular viscosity even at y=0. I suspect that the reason is F(y) function, which is used to obtain F_max and y_max. It reaches its maximum too early and then is close to constant, so, probably, the value of y_max is wrong. I have repeated this in Maple and got the same result, so the reason is some misunderstanding, not the bugs in code. Has anyone calculated F(y) for a flat plate? What shape must it have? |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[Gambit] External 3D boundary layer mesh | insaneflyz | ANSYS Meshing & Geometry | 1 | October 19, 2009 01:46 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
