Sample source code on sprays?
Old   February 23, 2005, 14:21
Default Sample source code on sprays?
multi
Is there any link/book with spray and liquid breakup ***sample source codes***?
Thanks in advance.
Old   February 26, 2005, 10:57
Default Re: Sample source code on sprays?
Bak_Flow
Hi Multi,
Yes there is a fairly modern text that includes some source code which may be useful for you:
Multiphase Flows with Droplets and Particles Clayton T. T. Crowe, Martin Sommerfeld, Yutaka Tsuji
There also is a code that was done a few years ago which you can find on this site's source code index that did some micro-scale multiphase with VOF method. NaSt2D
see:
http://wwwberkeley.ansys.com/cfd/CFD_codes_p.html#NAST
All the best,
Bak_Flow
Old   February 26, 2005, 13:12
multi
Great!
Sample code for SIMPLE-algorithm and solving Lid-Driven Cavity flow test is uploaded Michail CFD-Wiki 14 February 23, 2020 10:26
User-Defined Scalar (UDS) Source code lig FLUENT 6 October 15, 2014 12:12
SOLA Source code available AminFeizi Main CFD Forum 10 January 14, 2014 14:08
heat equation solution source code john Main CFD Forum 1 May 27, 2004 23:41
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
