LES and DES models for wind turbine
Old   April 19, 2011, 09:31
Smile LES and DES models for wind turbine
mohammad
mohammad is on a distinguished road
Hi everybody,
I'm simulating the NREL wind turbine.My model is based on SST.For wind speed 5.4 m/s and Physical time scales as follow I have the following results;
Time scale: 0.1----> exactly Not converged (No. of Iteration 400)
Time scale: 0.06----> very hard to say converged (No. of Iteration 1000)
Time scale: 0.01----> ???? but very hard to say it will converge( still running)
As I know, I can use LES or DES for the situations that RANS-based models are not good because of large area of separation.I searched in CFX to run my model with LES or DES but I didn't find it....
Now is there anybody to tell my how I can start with LES or DES?
Thanks in advance
mohammad is offline   Reply With Quote
Old   April 19, 2011, 22:02
Raashid Baig
cfd_newbie is on a distinguished road
Originally Posted by mohammad View Post
Hi everybody,
Thanks in advance
Dear mohammad,
1. Why are you running with Physical time scale, just choose the auto time scale option.
2. Have you made your grid correctly ? Take hint from many papers availaible for CFD simulation of NREL.
3. Try the new Menter-langley transitional model available in CFX for this. I think I have told you about the paper related to it.
cfd_newbie is offline   Reply With Quote
Old   April 19, 2011, 22:36
Smile
mohammad
Originally Posted by cfd_newbie View Post
Dear mohammad,
Hi cfd-newbie,
I remember that suggestion that you gave me; thanks again. and about your questions:
1- The speed of convergence with a appropriate Phy. time scale is much faster than auto time scale.( I think and i tested it)
2-I think my model is acceptable enough.( see my answer to Glenn Horrocks)
+ I'm now in the middle of this way...I want to finish the current runs first and then to check your idea i will do a mesh-sensitivity-analysis. Later, I will shift to your suggestion about "Menter-langley ".... [It's a long way...isn't it?? ]
3- As i told you, still i haven't read that paper. but one question; is "new Menter-langley " method available in CFX 10?
Thanks
Old   April 20, 2011, 01:21
Raashid Baig
Hi cfd-newbie,
Thanks
Hi Mohammad,
1. I think your first priority should be to get accurate results (even if it takes little more time with Auto timescale at least you will get convergence) instead of putting time on finding best Physical timescale.
2. Good to know that.
3. Langley menter model is relatively new compared to other turbulence models. It's available in CFX for more than couple of years now.
Raashid
Old   April 30, 2011, 00:11
Question
mohammad
Hi Mohammad,
Raashid
Dear Raashid...
I have done the mesh sensitivity analysis and I want to refer you to my new question...
http://www.cfd-online.com/Forums/mai...tml#post305659
I hope you can help me....
Cheers
Old   April 30, 2011, 21:48
Raashid Baig
Dear Raashid...
Cheers
ASAK Mohammad,
The link that you have posted in broken can you check and repost the link
Raashid
Old   April 30, 2011, 22:01
mohammad
ASAK Mohammad,
Raashid
Hi Raashid.....The website officials have changed the location of my post...this is the new address of that link...
http://www.cfd-online.com/Forums/cfx...tml#post305691
des, les, wind turbine
Spanwise Length and Grid Refinement for SAS-SST, DES, and LES Josh CFX 5 October 14, 2010 19:47
LES & DES turbulence models Seva Reehal CFX 5 October 18, 2009 08:44
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 05:59
LES and RANS region in a DES computation Residium FLUENT 0 October 18, 2007 10:44
DES or LES J.Gimbun FLUENT 0 February 22, 2006 03:42
