non equilibrium boundary layer
Like Tree1Likes
  • 1 Post By Bak_Flow
Old   February 26, 2005, 06:01
Default non equilibrium boundary layer
abdellah
hi all what does mean non equilibrium boundary layer. thanks
Old   February 26, 2005, 21:03
Default Re: non equilibrium boundary layer
Bak_Flow
this refers to the ballance of production of turbulent kinetic energy and the dissipation. When the 2 are in a rough ballance the turbulent boundary layer is said to be in equilibrium.
This has important consequences in turbulence modelling. We can fairly easily write the production terms and have some confidence in how close the modeling is to the true physics.
We always have trouble coming up with arguments for the dissipation terms and infact most models that use a dissipation equation have so many assumptions imbedded along the way that you really have to view it as a model equation.
A good place to start reading is the chapter on turbulence in Ferziger and Peric's text.
Best Regards,
Bak_Flow
hasanifte likes this.
Old   February 27, 2005, 06:17
abdellah
thanks Bak_Flow abdellah
Thread Tools
Trackbacks are On
[GAMBIT] problems in boundary layer yubaibai88 ANSYS Meshing & Geometry 8 April 19, 2010 21:07
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 15:11
3D Boundary Layer Mario FLUENT 0 February 17, 2009 04:40
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
boundary layer thickness 98.4F Main CFD Forum 1 December 29, 2000 08:23
