why different between "number tracked"and "the number of injections“?
Old   April 22, 2011, 21:14
Default why different between "number tracked"and "the number of injections“?
xiaoyu
xiaoyu is on a distinguished road
using DPM model ,the number of injections is 300/s, mass flow is 0,the injection type is single,transient model ,but when is calculating ,why is the number tracked more than 300 ???
for instance "Advancing DPM injections ....
number tracked = 25115, escaped = 311, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0
Parallel particle tracking concurrency: 20%"
advencing thanks for your help
xiaoyu is offline   Reply With Quote
Old   May 6, 2011, 23:25
Default Relpy
akita
akita is on a distinguished road
I think this problem related to start and stop time of your DPM. It means that after a definitely time the one more batch of 300 particles was added in your simulation due to unsteady tracking. Therefore the longer time tracking and the higher number of particle injecting. If you do not want like this, you can set start and stop time equal 0, it will be solved.
akita is offline   Reply With Quote
Old   May 7, 2011, 01:55
Talking Math.h file
abdullah Alhomidy
abdullah_alhomidy is on a distinguished road
Hi Dear
I am using FLUENT V 6.3.26 , could you "appreciated' email me the math.h file that used for building the wind profile equation,in UDF,please?
i got error in building the wind profile equation that contains Log function
thank you so much.
g200504690@kfupm.edu.sa
abdullah_alhomidy is offline   Reply With Quote
Old   May 8, 2011, 20:46
xiaoyu
thank u,using your tips ,the problem is sovled . I set start and stop time the same time .
Thread Tools
Trackbacks are On
Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Mesh Utilities 41 January 17, 2013 03:43
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
