April 23, 2011, 17:46 |
Multicomponent flow
Gary
Rep Power: 15 |
Hi all,
I am facing a problem with a multicomponent simulation I am running. My solution is converging, but a notice is being displayed in the solution stating that a wall has been placed at the outlet. Does that mean that the solution is wrong? Also, if the solution is converging, does it mean that all the equations are satisfied, including mass balances? From what I understand, a single temperature & velocity field is created for the solution, & only the outlet mass fractions are calculated. How do I find a specific component's outlet mass flow rate in a multicomponent simulation? Thanks. |
July 18, 2011, 14:50 |
Multi element airfoil
Kashyap
Hi i am looking for a strategy to block and hexa mesh a 5 element airfoil, can you please suggest a few strategies for the same. Thanks
July 25, 2011, 20:41 |
Rep Power: 14 |
Your question is pretty vague and I'd have to know what postprocessing software you are using to be of any help. Mass flow is generally just the surface integrated momentum terms.
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 09:49 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Can I simulate multicomponent flow in porous solid | galary | FLUENT | 0 | May 21, 2006 00:53 |
How to do this multicomponent flow in fluent? | jihn | FLUENT | 0 | February 4, 2006 10:24 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
