what is the most helpful software for calculating the leakage in a plug valve?
Old   May 1, 2011, 15:04
Question what is the most helpful software for calculating the leakage in a plug valve?
Mister
mister is on a distinguished road
What is a good software which could be helpful in calculating the leakage in a valve specially plug valves?
there is a gap about .02 mm between Plug and the body. there is a film of grease between these two Parts. there are Packings and o-rings, washer thrusts, check valves, ball and ball seats which have an important role in the process. we are going to see if the fluid could pass the grease film, or deform the body and leak to the other side.
thank you
mister is offline   Reply With Quote
Old   May 2, 2011, 08:42
Default midas NFX has capability to calculate the issue
Junho Lee
midasNFX is on a distinguished road
Dear
Midas NFX-CFD integrated TDyn CFD-Solver had been applied for valve leakage problem.
If you are interested in, please e-mail me in order to be given related data.
Best regards,
Junho Lee
midasNFX is offline   Reply With Quote
ball, ball valve, plug, plug valve, valve
