gfortran compilation
Old   May 3, 2011, 18:06
Default gfortran compilation
Hassan
HaKu is on a distinguished road
i have a code in gfortran...
i need to change the code so obviously i need to see that whether changes r fine or r there any errors..
so how can i compile the code for errors?? and then how to Run it...
regards
HaKu is offline   Reply With Quote
Old   May 3, 2011, 23:41
DoHander is on a distinguished road
Suppose your program is named test.f90, open a Command Prompt in the folder where your Fortran code is placed and write:
gfortran test.f90 -o test.exe
If you will see no error messages and you will obtain a new file test.exe then your original program was free of syntax errors. If you want to run the new program just write in the same Command Prompt window:
test.exe
Do
DoHander is offline   Reply With Quote
Old   May 4, 2011, 18:16
Chris
Eezyville is on a distinguished road
Send a message via Skype™ to Eezyville
Try this:
gfortran -g -o Output Program.f90
Output being the executable. The option -g allows the compiler to generate debug symbols for debugging. The compiler should catch syntax errors automatically. if you are on linux you can use the gnu debugger to debug the code. I don't know what to use on windows.
Eezyville is offline   Reply With Quote
Old   May 4, 2011, 20:08
RenardP is on a distinguished road
@Eezyville
"I don't know what to use on windows."
On Windows you will use the same gdb debugger ...
RenardP is offline   Reply With Quote
Old   May 4, 2011, 22:58
Hassan
thanks to all. ill check this gnu debugger....
Thread Tools
Trackbacks are On
errors during compilation and installation of OpenFOAM-1.7.x on Ubuntu 10.04 ftec OpenFOAM Installation 7 February 23, 2011 07:07
Compilation Order and Single Precision Issues gocarts OpenFOAM Bugs 1 October 14, 2009 17:19
Compilation Error when running Tutorial 2.4 zhihuali CD-adapco 7 April 1, 2008 07:34
Compilation error with uparm.f Raghu CD-adapco 2 May 30, 2007 02:09
Compilation Error.... Arnab CD-adapco 4 September 12, 2004 15:54
