porous medium
Old   March 15, 2005, 04:37
Default porous medium
antonietta
hi everybody! I'm simulating with Fluent a mass and heat transfer in a porous medium. unfortunately I've a problem: if I use air as fluid in the porous medium the residuals respect convergence criteria and the solution has a physical meaning; when I use water as fluid in rthe porous medium I GET LOW RESIDUAL TREMS AS far as energy and x-y-z- velocity are concerned but elevated residuals ( 1e+13) as far as continuity equation is concerned. why? how can I solve the problem? bye and thank you
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 06:32
Lack of local thermal equilibrium in porous medium Chander CFX 4 March 4, 2012 04:07
Modelling sound propagation through layered porous media nkinar Main CFD Forum 0 July 4, 2010 14:45
porous medium model, help please! cloudnqh FLUENT 0 February 26, 2010 14:27
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
